Does everybody who builds put them in? I'm currently working out a lighting budget/plan and I'm actually pondering if they are necessary? Currently I live in an old 1940's redbrick with one light fitting per room and although not really bright the light seems sufficient. So I'm assuming the same would then apply to todays modern pendants? So if I have pendants in the loung, dining, bedrooms and other living areas do I really need downlights? I'm sure I'll want them in the kitchen but everywhere else??
What have you done and why?
Speaking of downlights....
They were never intended to be used as the main source of lighting.
I'm only using them in hallways and for task lighting, in the dining room for eating, (I have a thing about seeing food) but there will be another lighting option there and in the alfresco as I didn't want to have to worry about light fittings outdoors.
Plus I think a lot of rooms can sometimes look soulless with downlights everywhere.
There's so many fantastic fittings out there to take advantage of to add character to a room.
Jo
No. not one.
I'm not anti downlights but they cost a lot of money and I'm not that fussed about them, just didn't seem worth it to me.
And I'm not sure what sort of house would be the right one to pull off the look, as Jo puts it, but pretty sure it wouldn't be a conventional country cottage look like ours
My name is Helyn and I have a confession; - I'm not haveing any downlights.
No. not one.
No. not one.
My name is 'chelle and I have a confession, I'm building a modern, minimalistic house, and I'm not having downlights (...well we're not planning to, and if we do they won't be halogen lights.)
As joles said there are plenty of other options out there if you want them, and I'm sure we'll find something that suits our house that's not downlights.
I just don't think they are worth the money, and then there are the environmental considerations...but I won't go there
Why hasn't someone designed a wall-mounted "up-light" that shines onto the ceiling, thus reflecting the light throughout the room? Instead of having a room with 6 or 8 downlights, probably 2 or 4 wall/up-lights would suffice! Even the same adjustable fitting could probably be used (although I imagine square-shaped fittings would be more popular than the traditional round ones, for some reason). Someone probably has designed it, but I haven't seen any (or bothered searching) and it'll be quite some time before (or if) they ever take off...
Downlight globes were firstly used mainstream in art galleries where they wanted to light up paintings but not fade them. To achieve this they needed a globe that would produce the visible light spectrum only and minimal heat spectrum (infrared).
MR16 globes (halogen downlights) were developed for slide projectors originally.
As they were a Dichroic lamp, they reflect all visible light and filter out through the rear reflector, all the infrared spectrum. Perfect for paintings!
Good quality globes are still dichroic but since they cost more and the original use has long been forgotten, cheap lamps now reflect all the light spectrum.
M. Multifaceted
R. Reflector
16. the number of 1/8 of an inch the diameter of the globe is. i.e 16 x 1/8=2 therefore 2 inch or 50mm
They are available in more sizes and differing beam angles to suit different applications.
still they are basically a spot light as they are designed to be directional.
So, the original intention and the desire not to reflect infra-red works against us today.
We'll only have downlights in the entry/gallery (so it won't detract the focus from my crystal pendant, lol), 3 or 4 over the kitchen floor area (am having pendants over the island bench and undercupboard lighting over on the other bench) and in the Lounge/HT room.
I have used them as:
highlights at the entry (but only when the house is on show),
over the kitchen bench (2),
in my family room (6)
and alfresco which extends out from the family room (6).
In the bathrooms. (4 main bathroom, 6 ensuite)
In the eaves down the side passage ways.
as uplights in the driveway
I have used the GE longlife globes in the bathrooms and living areas for the last 5 years without replacement.
The outdoor fittings, i have installed LED MR16 globes.
We were reluctant to switch over from halogen to LED because we were concerned about the cost but we eventually made the switch because of the skyrocketing power bills. We replaced 30 halogen downlights with LEDs just over a year ago and they have already payed for themselves purely in the decrease of our electricity bill and maintenance costs. I haven't had to change on light bulb!
We didn't use super expensive special LEDs, just the ones that our lighting consultant at ANL Lighting recommended. They just revamped their website too if you want to have a ** peak!
Plus someone mentioned previously that downlights are too harsh? That's probably because they are using the wrong colour temperature. Most LEDs will vary from Cool White (which is what you want to use for task lighting like in kitchens, bathrooms and reading areas) to Warm White (which is perfect for family rooms and bedrooms). Our downlights in the living room are dimmable too, which is perfect for mood lighting and watching movies.
