Flashing LED Downlight
We have one downlight that flashes rapidly for 1-2 minutes on initially being switched on. It's on it's own driver, no dimmer but on the same circuit as 3 other downlights plus a fan that has two globes in it. After the flashing it settles down and is fine. Any ideas? Is the driver on the way out?
This happened when an LED is connected to an existing halogen downlights. I have this issue in the pass and replaced the LED to a Phillips one and it works fine now.
TAYLOR 9W CCT CHANGING LED DIMMABLE)
Lesson learnt here? People who say they are gurus usually aren't
New globe didn't help. Ended up getting a sparky to change all 4 downlights to an integral type (Lesson learnt here? People who say they are gurus usually aren't
2
I know this post is from a while ago, but the VBA has some good guidance on this. https://www.vba.vic.gov.au/__data/asset ... 5-Roof.pdf
4/10/2023
2
AFAIK, flashing is a minimum standard. Out of curiosity is your window glass stamped with AS requirements in any of the corners of each pane? Im almost certan if theyre…
31/01/2024
1
There doesn't look to be any rebate in the slab to prevent water from scooting under the window. AS4654 is the Australian standard to look at/refer to. They have…
