Wide Angle (100) vs Narrow angle (60) LED Downlights
wide angle beams or narrow 60 degrees ones and what do they prefer.
I agree that it is good lighting design practice to throw light on walls and the ceiling, and in fact this is my preferred way of lighting circulation spaces, but this is best done using other methods, such as wall mounted up lights, ceiling recessed wall-washers/gimbles, floor lamps, pendants or cove lighting.
As a general rule I do not use wide beam (>60 deg) recessed downlights except for sometimes in bathrooms, store rooms, corridors etc - rooms where you don't spend a lot of time and where you just want light all over the place.
Also, the flat wide beam LED down lights tend to be at the low end of the price and quality scale (but not always)
I didn't believe Wide beams are any good for living areas. Problem is majority of the market in LED are wide beam lights.
Have you had any experience with Lumex (NovaLED Architectural) lights?
If you're looking for a decent medium beam low glare downlight, have a look at the green illumination Invis 10 and Invis 16, or the Domus Deep - I think they are both around the $40-$60 range. Still out of China like most residential grade stuff, but the better end of the quality scale.
I like the Wattsaver versions of LED downlights as they are high lumen and offer wide angles and high CRI which is critical for accurate colour reproduction
I have had one experience and it wasn't great to be honest. But it's probably unfair to make a judgement on that basis.
Is there any areas of your house that are suited to the cool white versus the warm white in about a 60 degree angle beam? I am looking at the Invis 16 in WW and maybe a few CW. They are as you know 16W 970 lm CRI 92 with 60 degree beam angle but IP23. I am also looking at the LED from Tigerlight- Tiger Cub 11W 877 LM 3000K Osram 5630 LED type with CRI of 85. It is also IP44 but has beam angle of 112 degrees. I will look at pricing and make a call on which one to go with.
I really like the Invis for price and good aesthetic design. Same with the Domus. I don't think much of the flat type wide beam ones.
The light is very similar to premium Titanium down light.
I'm with you I don't like flat wide beams.
But the wattsaver is not wide beam its 60 degrees from specs.
You could also try the Philips Smartbright Mini - they are around the $35 mark. Your sparky should be able to order through his wholesaler.
It seems with trades anything that's a bit fiddly and requires attention to detail is a big no.
Anything to make their life easier
<7 deg - very narrow spot
7-15 deg - narrow spot
16-22 - spot
23-32 deg - narrow flood
32-45 - flood
45-60 - wide flood
>60 - very wide flood
The most common would probably be flood or wide flood for general lighting. Ye olde MR16 halogen downlights when used in general lighting are usually 36-60 degree.
So all these LED downlights with 90, 100, 110 degree beams are essentially a new thing. I think it simply has arisen out of the fact that they are cheaper to manufacture than a downlight with good beam and glare control. It may also be to replace compact fluorescent downlights which do have quite a wide beam angle, but also had reasonably good glare shielding.
1
As is per usual for many of the past failed RWH regulations, it is probably traceable to a bureaucrat who's ego overrode the need to seek the appropriate expert…
4/09/2023
Hi, Seeking volume or semi-custom builder in victoria(east), which have existing double story wide floor plans. Seeking 18-20m wide homes with depth of 12-15m long. Or…
