Cougar Lighting CFL's
CFL don't like frequent on/off switching (every few minutes), but areas like kitchens are typically on for hours at a time.
Found the same shape globe made by Compton - they're lasting fine
13W CFL globes at the lower price point ($7-8) are rated for 5000 hours and perform extremely well from our experience.
It is fairly disappointing that the shop you purchased them from didn't make an attempt to rectify the situation for you on the spot.
1
1. optional, you can but normally just use the earth from the main switch board 2. should be enough but the distance determines voltage drop - sparky should work it…
15/01/2024
I have a really long hallway which is 1100mm W x 11500mm L I would appreciate if anyone can give suggestions to light it up with Linear LED lights that goes from wall to…
9/02/2024
8
What? It's a lighting question, the control joint is only needed at 12m centres, a bulkhead or change of direction will suffice as a 'break' in the ceiling, just make…
