What have you paid for downlights to be fitted?
Page 1 of 2
Hi all just wanting to know what you might have paid to have downlights fitted not by the builder but through an outside source? thanks
Hi gadgetman,
Through the builder - $130 each supply and install! (bloody ripoff)
Through the electrician directly - $400 for 10 supplied and installed (more like it).
John
sounds like we got ripped a new one.. $100 each and we only got about 15..
$100 per unit. Thats what we had been quoted. As always it would pay to get a couple of quotes.
How can some sleep at night ripping people blind.
The way we do it now is get the basics from the builder, of course I ask prices for certain things for some free entertainment, but then you just rock-up to the tradie on the day and offer cashies for stuff, it is absolutely amazing the price you will pay them when you pay directly.
Get this:
- Satellite connections for Austar/Foxtel through Builder - $220,
- Satellite connections for Austar/Foxtel directly for ca$h - case of grog $35
- Extra Integrity HWS Controller via the Builder - $265
- Extra Integrity HWS Controller directly for ca$h - $120
- Run 20m x 100mm ag-pipe with geotextile sock around garage via builder - you will like this - $1100
- Directly with the Drainer - $100 for the pipe and ANOTHER case of grog $35.
- Carpentry - raise a wall following contract signing - $1000 for the change and $220 for the work.
- Approaching the Carpenter directly - $0 (Don't worry buddy, there's enough timber here to look after it...)
So, my point is, we will all get rorted and screwed somehow, all we need to do is limit the amount...GO DIRECT TO THE TRADIES and show some polymer notes or cartons of beer.
John
If you're getting the builder to organise it, bear in mind that builders aren't electricians and have no idea how to quote electrical installations so they'll more than likely just be relaying what their electrician tells them with a bit of a mark-up (that's business), or they'll have an arbitrary number per point that is on the high side to guarantee them of a profit.
In an existing home, you might get the apprentice or worker using the boss' tools and cable to do it for $40 per downlight but that is awfully cheap and I dare say there wouldn't be many electrical contractors doing it for that price unless they are running their business at a loss.
I asked the same question here:
http://www.forum.homeone.com.au/viewtopic.php?f=31&t=15422&hilit=downlights
If I got the builder to do as many as Gadgetman it would cost $11,900!!!!!
We got our DL from ebay for 8.80 for 2 including trasnformers. Got one lot sent for the sparkie to check and he said they were just like the ones sold in the lighting shop here (same transformer and everything) just at half the cost
We were asked to pay $101 thru metr1con supply and install.
Outside $80 per downlight.
I thing i will say, we built first time and had it done by an electrician not thru builder. As a result we had to repaint all the ceilings cause you could tell they were done after.
This time we are gettting the builder Metr1con to do it, so we don't have that problem. Cost a little more but better in the longer term.
All the best!
Carla
Carton of beer each for two mates (certified sparkies) = $80 installation
total = $350, supplied and installed
5 outdoor lights
1 chandelier
1 air con output thingy
5 extra points
and putting in 8 clipsal saturn l.e.d light switches
cash direct $1750
i do them for $55.00 without the fitting.. thats switch, wiring and fit-off.
your getting an AWSOME deal
Hi I just saw this and think its excellent, but I was wondering how you went about doing this. Do I ask the builder when the sparky will be there and if so do I just walk up to him and ask him to quote for downlights? What happens to all the other lights or do I take them off the plan? Im lost, my first build Also what other things can I do cheap
I was lucky as we lived next door while we were building so I was often there to chat to the tradies (while not annoying them) coffee, soft drinks, home made cakes/muffins, (and beer late in the afternoon) go a long way to getting them "on side".
I approached the sparkie when he was first there and got to know him a bit and then mentioned what a rip off $177 for a down light was he absolutely agreed, I then said we would be getting them done afterwards by a friend, after a while he said he could run all the wiring and put the 413 plugs where we wanted them for $45 each, I said I would speak to my sparkie mate he then said how about $30 each and I figured this was quite good as he could do it before the gyprock we in so we agreed.
We also got him to run a junction box for the shed and put in another circuit.
Good luck with your project.
2
Hey Buddy I am so sorry to hear. I have been going through something very similar. In our case a client owed us circa $200k for the final payment and moved in without…
12/11/2023
13
Thanks mate. Yeah good points! Leaning towards Option 3 to get a bit extra space in the cabinets but not going too crazy high (and expensive). Would require a mini…
14/03/2024
8
Hi All, I just wanted to close this topic out with an update. So we ended up agreeing to a number with the insurance company, and after an extensive amount of hand…
