The dining one is 110kg, but there is a steel beam across the area that I want, so that's not much problem. the below ones are also mounted in floor joist areas:
120cm wide, 75kg, round, with a frame that will need to be attached (see photo).
180x34, rectangular, 90kg, supported by two chains (see photo).
80cm wide, 40kg, round, with a frame that will need to be attached (see photo).
Then there is one upstairs, mounted on ceiling roof truss (only one of these):
or
120cm:
80cm:
Rectangular 180cm x 34cm:
Chain mounts for above:
200 x 100cm (mounting on steel lintel):
I had some suggestions from another site for joists, but nothing for trusses:
The frames are mounted first, and then the plates are attached.
Note:
The plaster is already on, so this would require making a few holes, which can be patched and will be covered by most of the pendants.
Professional opinions please?
