Budget for lighting - post handover
I’m planning to get the builder to do standard batten lights/minimal downlights and a sparky to come in post handover to do the remainder for a 3x2. As such, I’m trying to figure out how much I’d need to budget for/save.
How much did this cost to do (if you did the same)?
I can’t figure out if a light is too expensive or not. (Ie a nice wall light for bedroom is $150 each which seems ok but it all adds up, is that too much to spend or is it standard?)
Thanks in advance.
1
Coming back to your old stomping grounds, huh? Renovations on a budget can be quite the journey. It's like giving your house a new lease on life. The twist of not knowing…
8/12/2023
1
1. optional, you can but normally just use the earth from the main switch board 2. should be enough but the distance determines voltage drop - sparky should work it…
15/01/2024
I have a really long hallway which is 1100mm W x 11500mm L I would appreciate if anyone can give suggestions to light it up with Linear LED lights that goes from wall to…
