Still remember that spammer telling us $50 a downlight is a ripoff and trying to sell his $5 led's on eBay LOL...
Idiot.
Incandescent & halogen downlights??
Page 6 of 7
Idiot.
One thing I really found of value was having both 70mm and 90mm. Meant we could have less lights in a larger area due to the light size. Saves money!!
Hi delatite, would you mind clarifying something for me - I'm very new at LED's but I know spending the extra money is the right thing to do.
When you say, less lights in a larger area, you mean by using the 15w 90mm, don't you? From what I understand I can place them 2 metres apart and still get good coverage? I understand that the cool white and natural white is brighter, but because we are keen on a softer more country look, we'd most likely prefer warm white. However with those we may need to go a shorter distance? I'd really appreciate yours, MissEm's or anyone else opinion who's more informed to comment please.
The DL7's are only a 75mm cutout so are perfect for new builds where the roof has no holes cut in it. They are a bit more inconspicuous being smaller in size, but share the same light output.
We wanted our lights to blend and certainly not be a highlight of the rooms, which is why we went for the smaller size and white rims instead of silver.
BUT what I think delatite might be saying is that the DL9 being a much bigger diameter light, it would I assume, certainly throw its light out in a much broader area, meaning you can space them further apart. ???
Can't really comment on the warm lights as all ours are natural, BUT you can get the wattsavers with a diffuser cover instead of the clear glass cover, which may give the natural light more warmth and not so bright if you wanted to swing that way.
Thanks again.
Good luck let us know how you get on with Stephen.
We went for natural over warm as we found them a bit yellow, but each to their own.
We have 4 x 90mm in a 7m x 8m room and if all turned up it is very bright.
Hi Delatite, do you mind if I ask how you have spaced the lights? I have been reading all the threads and am still very confused
we rarely run all the 4 downlights at any one time in our large lounge area.
Mostly we run the 2 lights above our couches only - which at rear of pic- above the couch .
Normal times they are all dimmed slightly ...only if reading ..do we turn them up
Just ordered my Wattsaver stuff for inside and outside... Can't bloody wait
Please don't forget to give update. Thanks
Well they get installed this Saturday so I will post up the results shortly after that. Might wait until my floor boards are in before photos though, so give me a week or so.
Wow so little lights for such a big space
Em is correct re spread of light, ie bigger diameter, bigger spread. Also will be softer of the given area ie not as intense. We have 4 x 90mm in a 7m x 8m room and if all turned up it is very bright. We also have 2 x 70mm over the dining area and their great for that area. i would choose the diameter that suits the area the best.
Given the same reflector angle the diameter will play little part in beam spread. The lights are either the same beam angle or they are not.
Thanks
