Ventilation when slab in place
Have an 1870 terrace in Sydney with some dampness / condensation issues on an internal wall.
After a lot of reading I have come to conclusion that it is due to condensation
- external wall rendered
- no vents external or internal
- concrete slab with floorboards a few cm above
Is it worthwhile trying to get ventilation into this very narrow gap between slab and floorboards?
Thoughts on air brick internally?
Any other tips?
Thanks 🙏
Evening,
Any other tips?
Thanks 🙏
Any other tips?
Thanks 🙏
Presumably the terrace contains similar houses of similar construction?. Have you asked the other terrace residents if they have a similar issue and how they have addressed it?
I used to live in an old terrace in the inner west which had a sub floor fan whirring on a timer-it did have vent to the outside though-from memory below the front room window. Have a look at the neighbours external front wall-you never know, someone may have got the idea that to prevent damp it would be a good idea to the seal vents....
1
Brass fly wire, you will need to cut it, shape it and jam it into brick slots
