I am new to this forum, Any advise on flooring is it good to be done with henley or better to choose from External Trades and which one is most cost Effective. Any info will be greatly appreciative
Thank you!
Hi, If you give a set of criteria as to what means 'good' to you, it'll give others prompts to respond. We considered Henley early on but there were two factors that…
1000000% definitely add insulation. I have in my home and it makes a big difference minimising sound transfer. Insulation is pretty cheap and definitely worth it
Engineering timber is certainly a less fuss option, times cheaper to supply and install and better withstands humidity.
