Grout Sealing - who's done it?
what products, techniques have you used if you have done it in the past, have you found it worthwhile doing for cleaning purposes? Are there companies who do this for you if so what do they charge?
Is it easy to DIY or should look for a professional?
I used a very soft fine paintbrush for the grout lines. Using gloves and a mask I painted it on, waited 15 mins and then washed the extra off with a thick sponge, otherwise a white residue is left on the tiles. I had two big buckets of rinse water next to me and did it section by section only, so I didn't run over the 15 min and risk the white lines becoming permanent...
The only thing hard about it was the fumes...they are horrible.
Can any of you advise if the smell lingers if I get it done professionally?
I've just put in an enquiry with GroutPro (thanks!)
So you did it yourself despite the smell? Can you advise which brand of product you ended up using and why? (PM is fine too if that is better?) Oh and the type of mask you would recommend given the fume situation. Thanks!!
Just look for a water base sealer from Aqua mix. It is safe to use.
Using a phone. Please excuse typos and autocorrect issues. And brevity.
Please note these clear sealers are not bullet proof. They only stop deep staining in the grout. The do not stop your grout from getting dirty at all. I have had hundreds of customers tell me that they wish they had never clear sealed there grout as they never saw the benefits. I tell them it is lucky you did because when it is professionally cleaned the grout will come up a lot better if it was unsealed. If unsealed the grout can look patchy after professional cleaning this is why grout colour sealing is a better option.
The difference between clear sealing and colour sealing.
Clear Seals only stop deep staining.
Colour sealing stops all staining and dirt can not stick to your grout. It will give your grout a uniform look and will stay that way for over 15 years. There are cheap versions of grout colourants at bunnings and masters that are NOT colour sealers they are cheap and nasty clear sealers with paint added to them just like grout pens a waist of money.
Unfortunately the place that I got it from had it sitting on the shelf for a million years and when I had to order some more I had to go to a lot of tile places to eventually get it. No one had any idea of what I was talking about.
Expensive, but worth it.
Sandra
I have professional applicators all around Australia. Grout Perfect is now used in most KFC and MacDonald`s restaurants. If you ever stay at the Crown in Melbourne or any other crown hotel you will see our sealer has been applied to all the bathrooms floors and walls.
Our grout colourant can be scrubbed or high pressure cleaned which you can not do that with other grout colourants as you risk in damaging the sealer or it may peel off. If you would like to see what it is all about you can visit my website at www.groutperfect.net.au
I am trying to send you a message via the website but there was an issue. So thought I'd send it here
I'm quite sensitive to VOCs and just wondering if the colour sealer off gases and when. ie is it just when applying and before it cures or do we need to wait for a few days?
Given that the colours aren't easy to tell what is the 'best' white to use for most people? (ie what's the most common one that your business owners use for their clients?)
After a few tries I found the easiest way to apply it was to use a pastry brush. This minimised wastage and spilling the sealer on the tiles.
Its too early for me to know how effective this sealer is.
Clear sealers sit just below the surface of the grout where as grout colourant`s sit on top of your grout. We have seen many grouted floors that have had clear sealers applied years ago and our customers always complain that it was a waist of money. In saying that when we cleaned them professionally they came up great where as unsealed grout does not respond that well during our cleaning process.
Hi, planning on using the attached stone pieces in my bathroom. I want to remove stains and gloss seal. Can I get some advice on best way to remove stains and best…
20/04/2024
Hi everyone Question about Brevis gas heating undergound - was recently installed by previous owners (<1 year old) but live in a relatively large house - 4 bdr - and only…
5/08/2023
2
Thanks splashers, that makes sense. The waterproofing guy used this Davco product, I will raise the issue with builder and hopefully get resolved with him - if not…
