Hollow/Drummy Tiles - builder won't fix
We had the builder supply and install our tiles (Perth Builder), however there were a number of hollow/drummy tiles about 100+ which we found. They said they have been replaced but we have found more tiles 38 which are hollow. The builder says they will not change them.
Does anyone know where we stand with them replacing the ones we have found?
Thanks
I had a few drummy tiles and I brought it to the builders SS's attention with a blunt fob off. Over time the grout started to fall away which isn't to the end of the world but it can cause the tiles to crack.
But 100, even 40 tiles is ridiculous!
I can not believe builders treat home owners like this. I hope you have not paid them yet but by the sounds of the builders attitude you already have.
Craig
1
ShaneG We have been doing heaps of hybrid floors lately. The hollowness is caused by low spots in the slab or subfloor. No slab or particleboard floor is going to be…
9/05/2024
1
how on earth did that happen? the tiles need to be replaced, I’d be checking the concrete slab too, either tile needs to be loose or the slab cracked I would think
6/02/2024
3
If the railhead is so poorly fixed it is also likely that the railhead is also non compliant, what about overflows and sealing railhead to the gutters?.
