3mm Grout line & which tile for my main floor
We have ended up with better choices and a bit cheaper.
The question is would you do a 3mm grout line to save 5.5K in extra labour charges or is it worth 5.5K for 1.5mm grout lines?
the next question is would you use the 30X60 Brown or 30X60 cream matt porcelian in your main living areas? I would love your opinion. Grout will be off white.
Our kitchen will be in a nocturine oak with white shimmer stone benches and steel kick plates.
http://wisdommajestic35onourland.blogspot.com/2011/11/tiles.html
The problem with a 1.5 ml gap is that the grout can not be sanded you have to use unsanded grout as sanded grout will just end up falling out over time.
Craig
I can not understand why they are cheaper for smaller grout joints as I have never heard of that before. In choosing a grout width size it all depends on the tile size. 600 x 600 tiles should have a 2ml-3ml gap and tiles that a smaller 5 ml gap.
Craig
Craig
Hi Craig
So what you are saying a 3mm grout line for a 300x600 matt Porcelain tile laid throughout all main living areas is what we should be looking at and 1.5mm is just going to cause us problems down the track.
Because if this is the case then it makes our decision a whole lot easier.
What do you think of the colour choices?
I am unsure why they want more money for 1.5 ml though. The colour you have chosen off white will not stay that colour for long due to how porous grout is. The matt finish tiles can also be a pain to keep clean depending on how you maintain them.
Cheers
Charlie
It could also be to allow for grinding & maybe some leveller as Zedman has pointed out.
We grind every slab regardless.
It could also be so they have some coin in there pocket to allow for any problems you may have later on.
I would ask the question on Australian Standards & want to see the standard myself, as I don't believe 1.5mm or even 3mm is acceptable & in my opinion too small.
We work on 4mm or 5mm on most floors.
We have Alpine Ivory Tiles with matching grout. They were laid 3 years ago and grout is still the same colour. I would say that our grout is probably 3mm wide (no problems).
The real question is are the Tiles chosen Porcelain Rectified Tiles ? if they are than 1.5mm joint wont be a problem as the tiles are cut precisely the same size. If not than dont even try using 1.5 just go for 3mm.
Next question is the laying pattern ? If you lay in a stackbond lay than it should be no problem but if you are looking at brickbond pattern than its hard to stop the lipping tiles of 30x60
The only option you should be paying for is for the Tiler to use leveling clip system which will help maintain a level finishing floor with even spacing.
1.5mm spacing is fine for main area floors but it is not allowed for wet areas. Get your floors inspected by the tiler prior to starting to make sure they dont need levelling or grinding before starting.
13
This is one of the reasons I decided to go overseas for my double glazed windows. As the builder indicated, he's worked on many upmarket builds, these were the most well…
5/08/2023
2
Thanks splashers, that makes sense. The waterproofing guy used this Davco product, I will raise the issue with builder and hopefully get resolved with him - if not…
29/04/2024
Have some black tiles in our bathroom on one feature wall laid on top of the waterproofing. What I think is efflorescence or white chalky looking grout has turned the…
