Wood-look Lino - anyone used & pics please
Thinking of putting wood-look lino in open plan living area, kitchen etc as real wood floors would scratch from sand and tiles - well I have them now and don't like cleaning grout! Other friends/family will be using the house too.
Has anyone used the lino that looks like wood flooring? How did it come up? Any pictures would be greatly appreciated.
A tip from me. I would be very careful about using a PVC floor in a non-perm dwelling.
The danger is that the heat that may build up there, if you are not living there, may wreck the floor. PVC is plastic, and plastic expands when heated.
So if you do want to use it, make sure you have adequate ventilation or insulation, use blinds and so forth when not there - or you may find it has buckled and warped after a 43 degree week in Summer.
A low gloss, highly textured laminate floor would be my reccomendation - to stand up to punishment from vistors and sand from the beach etc. Juts be mindful of not wetting it too much. It won't freak out due to heat, but will fade, just like everything (except timber) tends to when exposed to large amounts of sun.
Can you put laminate flooring in the kitchen? Or not, due to risk of liquid spills etc? I presume you mean laminate planks or tiles?
As title suggests, looking at using the interlocking Pentablock stacked stone products to replace failing timber retaining…
7/06/2023
We are tossing up between a Jarrahdale radiant wood fire (the Pioneer) and a convection wood fire (Innovator or Countryman) but cannot decide on which type of wood fire is…
16/11/2023
2
yeah i couldnt picture it issue either, but i could clearly picture what they were doing wrong haha
