Curtains and Blinds for Tilt and Turn Windows
We will be building a house hopefully later in the year and are planning on putting in Tilt and Turn uPVC windows as I love the idea of them (seen them plenty of times in Europe) and obviously because their performance is excellent. We live in the Ballarat Region so need good double glazed windows that seal up well.
The only dilemma I have is window furnishing Tilt and Turn windows. As they tilt and open inwards normal blinds will be in the way. I have seen custom made venetian blinds for them online however I'm not sure if I like the look.
I have already decided to go with awning style windows in the main bedroom and bathroom/ensuite because I would like to install plantation shutters to them windows. The kitchen window will also be Casement style (opening outwards) so not an issue there. I am however not sure if I can use normal curtains (with pelmets perhaps) in the living areas and roman blinds in the other bedrooms. Thinking any type of blinds (unless specially made to be attached to the window itself) are going to be in the way of opening the windows.
Does anyone have Tilt and Turn windows? What did you do in regards to curtains and blinds. I can't remember what they used in Europe, thinking it was just normal curtains on rod (no pelmet).
Also if anyone has these windows, have you had any issues or anything we should know before we install them?
The Roman blinds obviously will need to be retracted for the windows to be opened, but the honeycomb blinds can still be fully extended with the windows open (they go against the glass, not the window gap), so they can still be used for privacy/screening even when the windows are (partially) open. Hope that makes sense.
We've experimented with this type of dual setup (lightweight blinds inside the frame, heavier curtains outside) in our current house (standard single-glazed aluminium-framed windows). The thermal and noise insulation benefits from having the two layers surprised us - significantly better than from the curtains alone (we also live near a major road and noticed the noise insulation effects immediately).
Note that while blinds attached to the windows don't fully isolate the frames (and so aren't 100% effective), they still do provide a decent benefit. My understanding (and happy to be corrected on this if anybody has any data to the contrary) is that not covering the frames much less of an issue for multi-chambered uPVC frames (as opposed to standard, non-thermally-broken aluminium). So it its possible that we're over-engineering things, but that's the way we're going for now.
About a year ago, I embarked on a DIY project to construct an outdoor Pergola, which measures approximately 5.2 meters by 4.0…
28/05/2024
3
Actually kind of agreed with the first comment. Felt like it is a bit too much adding both double roller blinds with sheers, but it is not uncommon to do this - it…
2/03/2024
Flashings over doorways and windows our carpenter has installed flashings that is buckled and short of the window frames and door frames is this right Is there a…
