Confused over soil report - P and H1 and then UTP
Would love some advice.
Out soil report came back as "P (Depth of Fill)"
Then H1 (which I presume is under the depth of the fill??).
I spoke briefly to our builder who seems to think this is common and won't be a problem. He said developers often fill the land to make it flatter which is why it got the P rating initially. Is this true or is he trying to sell us a house??
The other thing I don't understand is at about 1m depth it says it encounters rock and then shortly after "Unable to Penetrate". Is this normal or a concern?? Sounds concerning to me!
The P stands for Problem. It means that the engineer needs to consider his slab design carefully and design it accordingly.
The H1 is a new classification that started last year and refers to the soil type used as the fill. It indicates a high clay content and subject to large fluctuations in movement when wet (swell) or dry (shrinks)
The rock at 1 metre depth is good structurally for slab. The engineer will most probably design a raft slab with concrete piers sitting on the rock platform and then supporting your slab. The slab will also need to be designed to resist the swelling and shrinkage.
I have seen some engineers make builders remove all the H1 and replace with controlled fill compacted in layers. This would be a better solution.
The other problem you have is the depth of services. If you have to dig any sewer or stormwater into the rock then it will be expensive.
All these things mean variations to the builder which means $$$$$ out of your pocket.
If I were you I would get an engineer on board before you purchase the land.
I have just recently been through the same thing. The purchase of the block was based on a favourable geotech report. It came back P so we pulled out.
We are still searching for another block.
If you already own the land then definitely speak to the builder again.
DON'T SIGN A CONTRACT WITH THE BUILDER until you know exactly what cost is going to be.
You might even re-consider a different design to reduce site costs.
Hooroo!
I'm reading with interest as I am waiting for a soil report to come back at the moment. Is http://www.engineersaustralia.org.au/si ... _part1.pdf still relevant?
Cheers,
Dim
Thanks very much Greenify.
I'm terribly depressed.
I can't figure out how to get this possibly massive site cost detailed/pinned down further without commiting to a builder survey/plan which would cosat $1500. It kills me to throw this beautiful land away on an offhand quotation from the builder (when the realtors say it wouldn't be that bad at all) ... but I guess it's what we'll have to do....
Any thoughts anyone?
Can you ask your neighbours?
Cheers,
Dim
In answer to your questions yes this is common but compacted fill is what you will need.
How many bore logs were completed and was rock found at all of them.
Can someone please offer some advice? Im DESPERATE. Because I'm completely and utterly exhausted. How long are variations taking with other companies at the moment? We…
19/08/2023
9
If this is a custom build then I would expect the builder to set out the door frame closer to the wall to avoid the gap between architrave and the wall and or specify…
4/02/2024
4
Hi Building Expert, Thank you for the feedback, much appreciated, there is also a code of conduct for building surveyors which they need to follow as well. I am looking…
