Stormwater Easement - How far from pool?
Would anyone know how far from the stormwater easement can a pool be? Hoping we can fit a 3.5m wide pool in. TIA 😊
You can build up to the edge of the easement as long as the bottom of the pool is below the zone.
See this link that explains the zone of influence: Zone of Influence
12
The OP has gone The latch and striker are definitely not aligned but there was no point trying to help the OP understand that. Hence the reason they are no longer with us.
19/08/2023
2
You should be able to encase the sewer but you will need it designed and approved and access to lot 580 to do the work
15/08/2023
1
You might be able to apply to divert the sewer at your expense. In NSW you would contact a Water services co-ordinator and they would give you advice as to whether or not…
