Building ForumPools & Spas
Pool pump issues
Recently, over the past week, I have noticed the pool is struggling to maintain pressure when pumping and circulating the water.
Today for example, I will have the pump on 2200rpm and pumps the water well. But when I carefully open the bleeding valve on the top of the cartridge filter, the pressure dramatically drops to the point that it stops drawing water.
Cartridge is new (4 months) and clean.
There are no leaks.
I have tried different speeds but no luck.
Any suggestions. Help.
I have topped up the water and it's 3/4 of the drain input.
Basket clear.
4
Stormwater drainage/ OSD/ pit pump/ absorption trench cost
Normally if they have the correct engineer you can go CDC. Do you mind me asking if you are using a project home builder as this could impact the process
18/06/2025
Sewage pump solution for KDRB home
General Discussion
Hi, I am having blocked sewage for which needs some suggestions for a sewage pumping solution. Any recommendations in South east suburb area. Ta
16/08/2025
1
How to lift this cover for sump pump?
Would it be practical to use a high pressure water jet along the border?
