Splashback behind/above sink regulations
We aren't having splashback behind our sink. Our bench is being extended out to our window and the window will appear to "sit" on the bench
We are in Vic if that makes a difference.
see you have chosen caeserstone? What did you choose? 😊
So many silly little regulations when building a house. I'm sure some of the "regulations" are just a case of the cbf's.
1
You need to reference the manufactures installation guide, your supplier may have strengthened the base where it is not required to sit on a bed.
14/03/2024
Old Home Restoration / Renovation
Hi, just discovered all these junks left behind under the floor. Could any of these be asbestos? Best to leave as it is or clean up? Thank you for your thoughts
4/05/2024
1
I might be misunderstanding.... but I would be more inclined to cut a section out from the cinder block wall and place the cistern in the cinder block wall. Very messy job…
