Offseting green of clear float glass
Looking at the colour content from photos of white on clear, it looks it would mainly need some red component, so some light pink paint should give a fairly neutral grey result. But then I was thinking surely lots of people have done this before and I would find lots on the web about the results. But after lots of searching I came up with virtually nothing, as if no-one was really even considering it.
Maybe I'm just not using the right search terms, but I'm hearing figures of around 200/m2 extra for low iron glass, and I'd expect if you could get a similar effect by just tweaking the paint colour then people would be trying to make it work. So does anyone have any ideas on this?
http://i1212.photobucket.com/albums/cc455/stewiesno1/Whiteonclearglass_zps7fe3cf41.jpg
White on starfire glass
http://i1212.photobucket.com/albums/cc455/stewiesno1/WhiteonStarfireglass_zps5a5f20a5.jpg
$350 m2 for float glass
and $450 m2 for starfire
Stewie
That's good to see the comparison. However, I can answer my own question. After going to a different splashback place, it looks like it is something they do. They use a colour with a bit of pink in it, which takes the green out of the glass, and you're left with something not far off white.
Sounds a bit hit and miss to me.
Far better to do it right from the start. Go for Starfire!
I basically thought the same thing as you and did a test on some scrap glass I got from a glass store:
https://www.dropbox.com/s/0ba0pcxzq1129ae/IMG_20150427_220224.JPG
It is really hard to offset clear float glass and achieve an off white as you can see in the above link...
I had been guessing a starting colour as Dulux Fairy Wings Quarter for a slightly warm off-white through the 6mm glass, but would have been aiming to try some glass over the top of some samples.
In the end we changed our colour scheme anyhow, and ended up wanting more colour in the splashback, so just going with one of the pre-done samples.
This is the look that I want for my polar white kitchen, do I just ask for "white on clear glass"?
thanks,
Sharon
Yes, you should just be able to ask for white behind standard glass. Be aware that the colour will vary a bit depending on the angle that you look at it from, so it would be good to check a sample from your splashback supplier.
Need to remove glass panel out of concrete without wrecking the glass to get the spa room in, any recommendations on how to do that. Thank you
26/10/2023
1
What do you need them to withstand? If it's normal wear and tear, then either will do, if you want resistance to ingress then laminated would be the favourite, but only…
