Just wondering how much people are paying to have their dryers ducted externally? We've just been advised $350 and thought that was a bit steep. The laundry has an external door so not far to do..
Thanks!
Cost to have dryer ducted externally??
Thanks!
If your dryer is under a bench, you may need to run the vent thru the cupboard with the laundry trough and out an external wall.
I woudl agree that in any case $350 is a bit steep!
Our new dryer in one of the condensing ones which doesn't need the air vented which you might want to look into if you are going to end up spending that much money anyways.
Its not just a matter of cut a hole:
Measure all cuts to be made with dryer in proposed place. This may require re mounting the dryer.
Cut plaster/brick/required areas and run ducting
fit off connections to allow good seal, check connections on dryer when re mounted.
patch brick/plaster.
Re paint as required.
Clean up.
I hope this helps, let us know what you decide.
HouseFenster
Hi all, sorting out the ducted air con for a 350sqm double story house. Does this placement sound reasonable to you? Also, I plan to have 6 zones I think. Living room…
11/11/2023
Hi all, sorting out the ducted air con for a 350sqm double story house. I think i plan to have 6 zones I think. Living room (mainly for entertainment so not used often),…
