Ugh! Our washing just blew up (seriously there was smoke!) and we're in the car off to get another one! Our old one was 5kg top loader! And it was okay . . . But need suggestions for a new one!
TIA!
URGENT- top loader or front loader and Why!
Page 1 of 2
TIA!
We have a front loader LG Inverter 7.5kg washing machine. LOVE IT. Can fit the doona in there. The agitator (sp?) bit in our last top loader used to eat our stuff!. The only downside to front loader... you cant open the door and add something in after you've started!!!
I have an Electrolux front loader and I can pause it and add things mid wash.
Front loaders are generally a better wash (subjective) and generally more water efficient than top loaders. But on the negative more expensive.
I'll take photos on Tuesday when it arrives.
We did however get a beautiful Westinghouse 610lt (side by side), in pretty pewter
Thanks guys! E, your quick response was good enough for me - we brought a Moon 7.5kg Front Loader. 50% off at the moment. So came down to a little under $500. It'll do for the moment, and we'll upgrade to a slightly larger one when we're in the new house!
We did however get a beautiful Westinghouse 610lt (side by side), in pretty pewter I'm in love!!! That beauty is coming with us!!
oooh! Cant wait for pics, your fridge sounds just dreamy!!!
Doesn't water gush out???
Only lets you pause early in the cycle, once it fills it won't let you for the reason you pointed out.
My wife has the idea that we should get a combined washing machine/dryer unit for our new house. Laundry space is at a premium (see houseplans in thread linked in my sig). Nice idea, saves space, but for a couple of grand ...
Does anyone want to either convince me to agree with her? Or warn me against it?
Bear in mind we are a family of 4, eventually will be 5, and also are using cloth nappies (kids are 2 1/2, and 10 months)...
The space-saving sounds like a great idea, but my problem with those is that it would take FOREVER to do a load, if you have to wait for it to wash and dry. We're a family of five, and I have both washer and dryer running often in winter. You can be drying one load while you wash the next.... Ours have been going non-stop all weekend for the past few months. Which probably explains the $500 electricity bill.
If you only use the dryer once in a while, it's probably not a big deal. Mind you, when people say they hardly use their dryer, it always make me wonder why they bothered buying one.
I will warn you against it, we have one and while it does clean - it takes around 4.5hrs to go thru a cycle. Front loaders are generally slower - but we found ours to be over the top. Our next one will be a top loader for sure
I'll second it, we got one as it was the difference between buying just a washer or getting a dryer thrown in, and at the time we lived in the tiniest apartment, so it was meant to be handy..
The washer component is fab, wouldn't trade it, but the dryer is crapola.. the clothes are continusously crumpled up, it can't run without a wash (eg if you forget to press the dry button, you have to run through at minimum a rinse cycle to get a dry out of it) and you can't just use it to fluff up your towels. And it does take forever...
The only thing it is good for is that you don't have to remember to change machines, eg take clothes out of the washer to put into the dryer, it just does it all in one hit. But it also ties up your machine for that long too...
Ours is an LG, and its about 3 1/2 years old.
When we finally get our new house I'll be getting an extra dryer, but there's nothing wrong with the washer.
I love our front loader. Bosch, yes it's a long wash cycle but there is a 15 minute cycle too, great for those couple of items you need in a rush. The maximum cycle is 2.5 hours. Wall mouning a dryer is going to make more efficient use of space of course too. Front loaders are more gentle on your clothes too, so they will last far longer and you can get a great spin out of them 1200rpm so much is almost dry when it comes out.
If I were you I'd buy just a FL washer. Hope that helps
But the good thing with sperate units is you can always dry one load while washing a second. Otherwise as mentioned, its a veeeeeeeeeery long cycle start to finish with a combined unit.
A front loader and a dryer stacked dont take up anymore room than just the one really, other than possibly some cupboard space.
This is what we have. We have a miele washer and dryer stacked on top. It even has a little pull out "bench" thing in between. I lurrrrve my front loader. Getting that after a top loader, my clothes felt soooo much cleaner. Mine has an express cycle which is 30 minutes and some of the other cycles give you an option to go shorter (although, that can still be 50mins or so). The longer cycles don't bother me as I am constantly doing washing anyway with a family of 5, so it gives more time to make room on the line or for the dryer.
Those two in one machines scare me. I'm sure they are safe, but the idea of them still seems strange to me
My system is perfect - I set my washer on a cold water eco cycle which takes ~ 2 hours which coincides perfectly with my 2hr drying cycle so they finish together! But same as you if I am in a hurry I can do the wash in 30 minutes.
Having said that, Chuq- def go for the washer with seperate dryer. You can also get rubber mats that go between the washer and dryer if you want to stack them. At least then as other people have said you can use your washer and dryer at the same time. If you're willing to spend a bit more you can get a condenser dryer so that it will eliminate the moisture from the room that a normal dryer gives off.
Front loaders take far too long. That's enough for me never to get one.
Hi, I'm in the process of making a footing with two pieces of trench mesh (4L12TM ) at the top and bottom. I'm wondering if anyone knows how far beneath the top of the…
14/03/2024
8
Hi All, I just wanted to close this topic out with an update. So we ended up agreeing to a number with the insurance company, and after an extensive amount of hand…
26/03/2024
2
A Sabco spin mop, minimal moisture, not very regularly. I was told these hybrids are water resistant 🤷♀️
