Where is your rangehood duct routed to?
And how far is the outlet from the rangehood?
for single story homes, usually a flume on the roof is used. not sure how its ducted for multi-story homes.
Here's mine:
I know with my downstairs powder room, which is in the middle of the house, has it's fan ducted outside on the brickwork also, if that's any help! The ducting goes through the cavity between the floors.
Mine is huge and looks like this:
Rangehood is usually ducted to outside.
If it's a toilet/powder room without windows it has to be ducted to outside as well. If it's just a extractor fan in the bathroom where you have window it might be only into the roof cavity.
What's your plan/addenda stating?
For the rangehood, the filter collects the oil droplets so it is really only air that gets sucked out. That's why it's important to regularly clean the filters.
My internal ground floor windowless powderoom is ducted outside, the upstairs bathroom and toilet fans are all in the roof space.
I ended up buying my own appliances and now i'm in the dilemma of whether to pay the extra money for the duct or just to leave it in the floor space.
any comments will be much appreciated.
cheers
Eta: Not sure about the powder rooms ... they have an extractor fan, so I figure it's only going into the roof cavity.
Bathrooms just vented to ceiling and whirlybirds take it from there.
@kev205. You can't just vent it to the floor space between ground and top levels. New regs say it has to be vented outside. Unfortunately you'll probably have to pay for the ducting or get a recirculating type range.
They do work quite well. The filters are good and wash in dishwasher most of the time.
I think its a rip off...
Cheers,
Earl
The plumbers I use here in Brisbane all do rangehood ducting...I could put you onto one if you are here.
Again in Qld, we even have these guys http://www.riads.com.au/ who specialise in rangehood installation - maybe they could recommend who to call in your area - or you could try some airconditioning/heating installation people for a referral.
Good luck,
Earl
P.S. Have just done some quick Googling and found hits for Rangehood Installation services in N.S.W. and Vic so there is a good chance someone there can help you further.
Hi everyone Question about Brevis gas heating undergound - was recently installed by previous owners (<1 year old) but live in a relatively large house - 4 bdr - and only…
8/05/2024
Hi, recently a replacement rangehood was installed at my home and the installer cut holes through the double brick wall for the duct but left quite some damage to the…
7/05/2024
1
Canopy and Undermount are best, and need to be ducted externally. Which one you go with will be largely determined by your design and joinery choices. What you should be…
