Gas cooktop
SIL's home cooktop is not working properly. They want to replace a new one, they are using gas cooktop.
So can they buy a new LPG cooktop for replacement? Or a natural gas cooktop?
Thanks.
Most new cooktops come with both types of jets in the pack - and the gas fitter changes them as required to suit the installation. If not they cost about $50 or so to change over.
5
My daughter and son in law are about to start building, they are having a 600mm induction cook top and 900mm oven. It's personal preferance >
6/09/2023
I want to build a decking to the drawn shape outlined in black. The problem is how close can I build to the gas hot water unit? Will I be able to build around it and be…
20/12/2023
1
you need a fridgie to answer but I would think you vac the whole system then add gas if you have a leak, unless it is new install with the gas already loaded, in that case…
