How to transform your balcony into an outdoor dining area
Below are some interesting ideas you can use when considering to transform your balcony into an outdoor dining space:-
• If you want your balcony to look like a garden, install artificial grass on the floor.
• You can also lay out interlocking deck tiles on your balcony floor or combine them with artificial grass.
• Paint unwanted crates and use them as tables or shelves.
• Use railing planters to arrange pots neatly on your balcony railing. You can also plant herbs and flowers in garden containers or use vertical garden stands to add more greenery to your balcony.
• Add a small grill to your balcony space. If can, get a balcony grill as it saves space.
• Add a bench and place an outdoor bench cushion and other normal cushions so you can have your meals at your balcony.
• Place an indoor water fountain at your balcony for the sounds of water.
Have any of you turned your balcony into an outdoor dining space? How did it turn out?
Now I have space for entertaining....
http://i637.photobucket.com/albums/uu98/bellao4/deckAgust.jpg
http://i637.photobucket.com/albums/uu98/bellao4/dec%202014%2011.jpg
design inspiration. All you need is a few pine boards, screws, wood stain, furring strip, and a cushion from IKEA (or anywhere else). If you don't like the look of the wooden paneling edging your balcony, you could grow plants and vines for added appeal.
Check out the video for full instructions and details of the materials and tools you'll need.
[youtube]https://www.youtube.com/watch?v=GM8QRFkybPg&feature=youtu.be[/youtube]
You may have a great outdoor space, but if you're overlooked by neighbors, this is an easy way to make it a little more secluded and embrace real beauty of Check out the video for full instructions and details of the materials and tools you'll need.
CDC Housing Code 3 When to apply Floor Area external face of wall vs Gross Floor Area internal face of wall. Reading thru CDC Housing Code 3, lets take a lot 915sqm.…
9/07/2023
First time building 2 storey home in NSW. Below Current plan have separate balcony. But thinking to do a multipurpose lounge with balcony (kind of sunroom) in first floor…
18/07/2023
4
Well you won't get cooked by the afternoon sun when sitting out on the balcony on a summers afternoon but you won't have much to look at besides the neighbours…
