Does white oil paint yellow?
I recently read on a design blog I follow that she had a terrible time with white oil paint (on her wood trim) turn yellow within a short period (less than 2 years). We are beginning to start painting next week and plan on painting all the trim with white oil paint from dulux.
Does anyone know how true this is/experienced this?
Thanks.
Hi
Thanks.
Thanks.
Can't see Dulux paint doing this, more likely that the substrate was the problem, perhaps painting on top of a stain, or untreated timber.
Ed
Can yo confirm if the rooms are naturally dark??
Also if the paint was mixed with too much turps this can also make it go more yellow apparently.
This is the information i got from my paint rep who is also the techinical rep for the region.
http://aubreyandlindsay.blogspot.com/20 ... llows.html
My apartment is naturally dark so this likely to be a big problem. Is there such a thing as high gloss water based paint or is there only semi gloss?
Paints like Dulux Aquanamel do come in high gloss, i believe. I tried water based "enamel" once but it's just not as glossy & hardwearing & doesn't have the finish of a high quality enamel paint IMO.
What the?! I've never seen anything like that pic. Surely it depends on the paint? And the only thing i thought would cause white paint to yellow is UV.....but that's not the case if it's yellowing in the dark. Fascinating. I have used enamel in shades of white (antique white, berkshire white etc) for at least 8 years now & am yet to see this.
Dulux Aquanamel = water based.
Yeah, i know. Used it before but it's not the same gloss level as premium oil-based.
Fortunately, in my old house, the walls were darker than the trim, so it didn't look obviously yellow until we painted with fresh white enamel again. Mum and Dads 4 year old unit has white enamel trim, and on the inside of wardrobes that never see sun have slightly yellowed already...
Non-water based paint will yellow, no matter what room ambient or underlying timber or anything else.
Luckily, these days the water based paints are fabulous. They are also available for external use.
White water based paint will not yellow and is also easy to work (and sleep
I used water based for all our internal and external trims, doors and windows. It was like brand new some 8-9 years after painting (and then we demolished the house). Plus, I used one of the cheapest paints available - Performer from Kmart and it's fanstastic.
I don't understand why would people even consider non-water based paints these days. Our friends did a major reno and their painter did all wooden stuff in oil based paints. After some short time, it all started to yellow and it really looks dated and spoils their clean modern look.
Hi
Thanks.
Thanks.
Ed
Of course it goes yellow!! Aquanamel wont yellow, isnt a true enamel, but will perform very close to it.
If you decide to go for a true enamel, make sure its on the exterior of your house as UV light will naturally "bleach" it and it will maintain its whiteness, inside a house UV light wont be at a high enough level to maintain its vivid whiteness.
I'm about to put down some Merbau. Is it necessary to oil underneath the boards before laying?
2/03/2024
Hi, as per the subject. Does anyone have any recommendations for the best value decking oil (Bunning is close to where I live) for a treated pine deck? Thanks
18/11/2023
Hi guys, I want to do some floor levelling before laying the planks and am considering doing it with self-levelling or yellow tongue PB board. I am wondering which one…
