Hot west facing garage
The temp in the garage impinged on the house via the single brick wall between the garage and the kitchen to the point where items in the WIP had to be thrown out because they got too hot.
Ceiling is insulated with 3.5 Batts.
First step - install ceiling fan in WIP to draw air conditioned air into WIP.
Second step - install aircell foil insulation in garage door - increased differential between outside and garage by ~2 degrees C
Third step - install shade sail to provide shade on garage door - increased differential between outside and garage by a further 2.5 degrees C
Fourth step - replace aircell foil with 40mm M grade polystyrene - no effect at all - quite surprising
Fifth step - install weather seals to gaps at top and sides of garage door opening - no discernible effect
Sixth step - still to be done - fit temperature activated exhaust fan in garage ceiling plumbed externally and fit and air vent to bottom of door between living areas and garage.
Any other ideas?
http://steel.com.au/products/coated-ste ... sification
These colorbond type doors take a re-paint real well.
(I don't think best doors can help in WA but something similar is an option..)
https://www.bestdoors.com.au/residentia ... rage-door/
https://www.bestdoors.com.au/media/1287 ... ochure.pdf
Hope this helps.
3
It might be a bit darker in the mornings but the light is still light, so you should be getting it. Similar to what you see from your western windows
7/09/2023
6
The warning is on the sticker on the door too. Second the aluminium powdercoat
1/06/2024
Help!! I’m meant to start building soon and have only really just learnt about orientation. Im reading so much that no grass will grow on the heavily shaded south…
