Blistering in exterior paint work
Page 1 of 2
In the January I reported to the painter that there was blistering in the paintwork, he said he would fix it.
Some of the work was fixed in August. I had a look after it had been fixed and notified the painter that there were still other areas that needed fixing. He said they would be done.
As it is a rental property I went to have a look at the next property inspection and notified the painter that there were still blisters in the paintwork that had been there originally.
He decided that he had to call in the Dulux expert to have it tested.
He has now decided it's not his responsibility and does not want to fix the blistering even though it occurred during the warranty period.
We had a house painted in January 2018 by a professional painter with a 1 year warranty.
Any suggestions on what I can do?
Thanks
Moisture content in Timber
Ideally 10-15%. Goodluck
I suggest you get a moisture meter and check the Ideally 10-15%. Goodluck
So if the painter followed the specs this should not have happened and I think he should rectify the work.
I concur, but people make non-critical mistakes such as not checking the flashings & Moisture barriers, and it's too late now
The painters off the hook. Contact the painters registration Board
Sorry I'm not sure what you mean by checking the flashings and moisture barrier , where would they be?
It's a 1950s weather board house on concrete stumps
Blistering is occurring at the nails and corners are they adjacent to openings ie windows? hth
The photos indicate the moisture is on the inside of the wall
No most of the bubbling is in the middle of walls not near doors or windows.
A few more pictures
The problem appears to be within the wall
Do you have Bathrooms or wet areas nearby inside the house are there water pipes within the wall?
Along with Photos/images I do recommend that you have the correct tools & data when problem solving
as there are many solutions
Contact your Tool specialist store, see if you can hire or purchase a
Cheers
Cheers
This video is probably a little more informative regarding tool uses, please post back once you have determined whats within the wall, pity your painter didn't have one?
Cheers
Cheers
The walls back onto bedrooms lounge kitchen dining bathroom, basically all walls have some affected areas.
Cheers
Cheers
Sorry I can't see the video
It sounds like a problem with your computer software, browser, java script, whatever?
If you have a mobile device/phone that plays You tube videos
Then watch this on your phone and update your Computer Software/browser
What to do if Google chrome can't play YouTube videos or any other video
hth
hth
I think it's a problem with your post. There's no video attached or linked to.
Here the screen shot from what I am seeing and it works, I am wondering if it's an issue with Homeone
and here's the link
Bosch DTECT120 Detector
First you'll need to detect the issues,optimal solutions are forthcoming
cheers
Chris
5
I posted the floorplan on Houzz.com forum and got some really good ideas and advice from people there. Then we reached out to a couple of renovation companies and one…
25/02/2024
1) I had requested R6 ceiling insualtion batts, however I noticed that on some areas there are huge gaps which will allow hot air to sweep in, and also noticed black/grey…
16/04/2024
1
could be the footing or being hard up against the other wall with no expansion joint or both. You could try again with brick mesh and use some sticky back foam against the…
