Widening fridge cavity
I have a fridge cavity which is 1185mm wide, but we need to fit a pigeon pair fridge and freezer, which are 600mm wide each!
The cavity is standard timber framing and plaster, not cabinetry. Is it worth considering widening the cavity?
Cheers
Jim
3
I would find a local carpenter or two in your area and get a quote. You will need someone who has the ability to saw cut your bricks and install a new lintel above your…
23/03/2024
3
I had a similar issue with my fridge not too long ago. It wasn't the same model, but the symptoms were pretty much the same: the compressor would start and then stop…
