Paint eaves and gutters yourself!
you wouldnt happen to be the patent owner doing some advertising here, would you?
http://www.paintingbuddy.com.au/
Ever tried to cut in with a paintbrush on a 3m long stick? Don't
This product would be good for touch-ups though, and probably needs to be marketed as such.
The DIY project can be broken into two major steps. Planning and Design and Construction. Both of these steps are as important as one another to ensure you give…
22/12/2023
4
The two 15mm holes are obviously not compliant. The Dept of Fair Trading would love to see this one! Do the gutters pool water after it stops raining? Although it's…
7/07/2023
7
Update from me! Couldn't find the trimmer - not sure if there isn't one simply because the eave is so narrow. Went ahead with the spring toggles and it all worked out…
