Ceiling leak and there's something odd up there .....
I got on the ladder and inspected the ceiling and surprisingly the section of loose paint came away (about the size of a small saucer) and there was only some light brown fibrous material behind it - nothing solid at all! The room was built in the 1960s; could they have used plasterboard with fibres through it at that time? If so, the actual plaster seems to have dissolved away, leaving just the fibres and the paint. Is that possible? I am really stumped by this and hope someone can throw some light on this.
With rain expected again in two days, is there any band aid fix I can do? I already managed to turn down the edge of the cliplok with a pair of pliers, hoping to break the capillary action.
If your ceiling has been leaking for quite a while most of the plaster in that section has probably dissolved away leaving mostly the fibres only.
Depending on your Kliplok thickness you can lay those sheets down to 1º pitch for the 0.48mm thick sheets but otherwise I think the minimum is 2º for the 0.42mm.
1º is 1:50 slope.
Stewie
I started calling roofers today. There's not too many in my neighbourhood (Chatswood). Can you recommend anyone from the Northern Beaches? I know some tradies who often travel down from Brookvale or Narrabeen to my area, just don't know a reliable roofer.
Ridgeway roofing may be able to help ( Brookvale ) but I haven't used them.
Stewie
2
If you make sure all taps inside and out are turned off, what does the water meter show if you leave it for a while.
8/10/2023
Hi all, I am hoping someone has some ideas as to what is causing my bathroom leak. The leaking appears to mainly happen when we turn the sink basins on. It takes a while…
9/01/2024
3
Are you doing this with a building permit? Conversion of a non habitable room into a habitable room requires building permit.
