Demolishing masonry wall
I have an indoor free standing 190 mm masonry block wall that I'll like to remove. It's in a U-shape with two walls reinforced, with windows, and one wall "hollow" wall. Will a chisel and sledge hammer be enough? Mortar chisel tools? Any tips?
Thanks
Alan
Stewie
Is it a load bearing wall ?
Stewie
Stewie
Hi,
I think "free standing" probably implies it is not. In that case a lump hammer would do it brick by brick (less messy), or a hit or three with a sledgehammer if mess and flying bits of brick are OK.
Start with the less supported bricks at the upper outer corners and work your way down.
Cheers
4
Thank you again Simeon.. I will call my certifier for that. Have a good day
27/06/2023
1
can’t tell from the photo, a tie down rod will be 12mm, is it a steel beam? he should be able to work it out
2/07/2023
It sounds like you have a crack in your garage where the wall meets the ceiling, along the shadow line on the…
