Backyard cabin: dig electrical trench before or after?
If the trench is dug before the cabin is built, there is a danger that it will be right in the spot where the cabin posts will go.
The cabin needs to be positioned 900mm from the boundary. If the trench is dug afterwards, is this a large enough gap for the trench person to do their work?
Any idea where to look for such a person in Sydney and what it might cost? Depending on the direction of the trench, it will be 9 to 12 meters long.
I will throw in data and an antenna cable. I hadn't thought about security, but if I need something later, I'm vaguely hoping that it will be possible to pull-through stuff later. Not sure how realistic that is considering there will probably be a couple of bends.
So do I just find someone with a trenching spade and lots of energy?
for your trench, find someone that operates a dingo or hire one yourself. It's much smaller than a bobcat but for your purpose should be more than enough.
When laying other services in your trench, to be compliant with eg. comms regs there's minimum separation from the power cables. I'm not exactly sure what this distance is off the top of my head but maybe someone who works with comms can chime in about that.
If laying conduit with the intent of pulling through cables at a later date, try to use sweeping bends instead of elbow joints and pull through a decent draw wire which isn't going to break halfway.
hth
Hi, I'm in the process of making a footing with two pieces of trench mesh (4L12TM ) at the top and bottom. I'm wondering if anyone knows how far beneath the top of the…
21/06/2023
10
It's possible but a soak well is usually much larger. Your 'soak well' only holds 424 litres when full. What is your soil type? Soak wells need sandy soils.
