Hi,
I am in the process of looking for building a new house and found the Rawson homes Edge design to be very attractive (though very expensive
Just wondering how safe is the flat roof (as shown in the
http://www.rawsonhomes.net.au/home-desi ... M57G0I3C5I )
The Edge Elite facade has more than $ 52K price tag. Not sure if this is because Flat roof is expensive or it is because of the difference in the material used to cover the front part.
Any input highly appreciated.
Regds,
Adams
A flat or semi-flat roof with the right profile of roof sheeting is fine.
What's not 'safe' is when walls are extended up to hide the roof profile and then have a concealed box gutter behind the wall. While builders say that they don’t leak, homes with box gutters that I’ve looked at buying before deciding to build, all had evidence of water damage due box gutters above.
The facade you linked to will be fine if roof profile behind the walls drains away from the parapets.
Good luck!
or if your building in an area where it snows
I'm not a big fan of a flat, or flat looking, roof.
In my opinion they are either very expensive and/or are at high risk of water damage to the rooms below(for more see
http://www.anewhouse.com.au/?p=3579)
You're onto this guy again JJ !
We can't get away with anything on this forum
Stewie
Every time I've seen somewhere with a flat roof I've heard of never ending leaks, I'd never do it.
your probably right, it is maintenance, but who wants to do any work on the roof
Not at all. If you have a competent roofer and/or builder supervising then you won't have any problems. A lot of the issues arise from the design side where there is not enough room ( usually height ) for a decent box gutter or flashings.
Get this right from the get go and that is half your problems solved.
Stewie
to be fair, all my issues with horizontal roof's leaking are generally due to bad workmanship of people installing things after the fact (so tradies stuffing up the sealing or causing leaks by drilling things into the roof and not sealing adequately around them, or the sealant not lasting) but how often do you hear of this on a normal roof? they are pretty bullet proof.
A mate - across the road in my old place - never stops complaining about it. Mainly the cleaning side. He mentioned leaks but its mainly the leaves etc. It looks good though.
Depending on how it's done it's very hard to add in wiring/systems in the roof as well, that's where you get tradies making holes in the roof to throw stuff on top and causing leaks
