Hey everybody, I need some advice on building a floor for my workshop, I want to build it like a house on stumps, the workshop will be a 9m x 6m colourbond and will be used to build my race car so needs to be structually strong enough for a car and engines on stands ect ect. My thoughts were 90x35 treated pine 600 spacing and layed in both directions, with 22mm tounge and groove flooring, stumps every 1.5m would this be strong enough?
Cheers
Timber floor for workshop
Cheers
Once sealed appropriately, the concrete floor will resist oil, petrol, diesel, coolant, brake fluid and a whole manner of other things that should the sealant degrade and be penetrated wont rot out the concrete like timber.
I would recommend setting it will a fall to centre and installing a drain with an interceptor to catch any big spills also. You can get systems with removable catchers and this means you can just let oils and such drain in then remove it and clean up properly after wards with out making a mess.
I also recommend an epoxy coating. It'll cost a bit more than want you(I assume)to spend, but you won't have to replace it n a year or 2 either.
I think you should also consider using blue tongue flooring if you can get it. I'm not sure what spacing it has specified though.
An engineer or even someone who specializes in commercial flooring should be able to work out the load it can handle and the load you'll put it under.
I remember those floorboards were very wide (as they all used to be back then) but they were oil soaked over time which made them waterproof. C&K I think vinyl flooring would be dangerous if oil/grease gets spilled...and it's bound to happen when building engines etc.
While I can't remember bearer and joist spacings I do recall the old power poles used as stumps that he set into the ground...no concrete anywhere. I think he got the power poles from a site he had been working on and while they were condemned for carrying power cables they were still in good enough condition to support this huge shed for many, many years. In fact when we pulled it down it was only because MIL wanted it gone out of the yard (he had long since gone) and we were most surprised at how strong it still was as it had been built from recycled timbers and always had heavy trucks/equipment parked on it all the time and I guess it would have stood another 50 years without any problems. It was a huge shed and also very high, the front door was at regular ground level then the land naturally fell away from there so the last row of stumps would have been 1.5m of exposed post.
I know this is not common building practice these days but for what you want it might be worth considering and if you can use recycled timber as much as possible that will help the budget. Exterior cladding could be colorbond etc so it looks good from the outside to keep council and the neighbours happy.
Could you build it in sections 2400mm wide so it will be more easily dismantled if/when you have to move?
Just my 2 cents!! LOL Btw, what category race car?
Then as you are 'building a race-car' there may be noise concerns when car tuning etc as their exhausts are rarely quiet, which may upset the neighbors and possibly end your race-car building or even end your rental agreement.
Much homework is needed here.
I am not afraid of hard work so the labour part is a non issue I just need a plan to work with, My yard falls away like happycamper was descibing thats why I wish to put it on stumps which will end up about 1m high at the rear.
The race car is for the drag strip, N/A mod street, 408ci tunnel rammed cleveland in a TF Cortina LOL good times
Cheers
Cheers
Cheers
I don't think it would be strong enough, but I'm no structural engineer! I'd build the subfloor out of steel (or hardwood) then 25mm hardwood flooring and don't use utility grade. I would also pour two parallel slabs for the car to sit on if you don't want an entire slab...given the size of your shed it won't be cheap! How about a pic of the car....
Cheers
-Steel sub frame, steel C channells maybe.
-Steel checkerplate finish.
-When your done with it all you can disassemble and move it, or flog it for scrap.
Good Luck.
Pat.
1
Engineering timber is certainly a less fuss option, times cheaper to supply and install and better withstands humidity.
5/09/2023
1
The most likely cause of your timber swelling (parquetry?) is either a plumbing leak or carelessly leaving water on floors after use or both. Without seeing, i am ignoring…
29/09/2023
6
Thank you. Do I use timber floorboards for stairs or do people use timber treads? Or is both the same?
