Putting Colorbond over concrete roof tiles
New here so go easy please , I have a concrete tiled roof that I want to replace with colorbond I was writing about this on another solar panel related forum ( there are 24 panels on the roof plus apricus hotwater system ) and someone suggested to lay battens and then put the colorbond on leaving the tiles there . This would 1. save removing the tile and 2. add to the R value of the roof .
Roof strength would be one issue are there any other issue I should think about ? I have two skylights and two domes ?
Cheers
David
Thanks for the reply Flatlined .
David
3
Are you doing this with a building permit? Conversion of a non habitable room into a habitable room requires building permit.
2/01/2024
2
Do you have solar on the roof, because if its not a laying defect it looks almost like someone has been walking all over the roof in the mid section of the tile (weakest…
17/08/2023
1
Your house roof does not show rusting other than some surface rust on the flashings. In my opinion you dont need to replace or paint the roof other than treat surface rust…
