Can I build above a brick pier garage
Will I be able to build a bedroom above this without an issue, or will internal framing be required?
Thanks.
Design Question- Large Garage open spaces
As for your design? ..(crickets, crickets, crickets) humour
To avoid silence try putting up a floor plan , photos, engineering
The more the info you put up, the better the response, plus it also helps others
2
Thanks for that!
14/06/2023
17
Have look at your house plans and you will probably find that brick articulation joint has been missed. Maximum allowable spacing is 6M or 5.5M for a wall with window…
21/05/2024
1
Turning this into my DIY shed makeover. I had a brickie fix the back wall up and it's rock solid now. I'm into ripping down the inside ceiling that was installed and…
