Security system, is it worth its price?
A bit controversial question but I've got 3 different Home insurance quotes and the difference between "I have a security system with back to base" and "I have nothing" is literally $50 a year. I'm assuming their quotes are based on real data which would indicate it is not worth spending $1k on a security system. Am I missing something ?
We don't know the value until it happened.
It does not mean I recommend because of the business, totally personal choice.
A considerable ongoing cost for little real benefit.
To see more reasons check this link https://anewhouse.com.au/2015/05/monito ... ar-alarms/
bashworth,
If I understand correctly your link then you will get a security alarm but not the back to base option. Is that correct?
Hay If I understand correctly your link then you will get a security alarm but not the back to base option. Is that correct?
Personally I don't see the value of a back to base monitored alarm but can see why some do. You could go with a system that will self monitor via sms or email instead or not at all and you only find to the alarm has triggered when you get back home.
Hay bashworth,
Not even sure I will bother again, but definitely won't be getting a monitored one.
syautd says, the issue here is about the safety of your home just by having the system installed for people to know that you've done the necessary and deter them from even trying...
I'd agree. Why risk not installing protection for your home just to save that bit of money. The difference in insurance really shouldn't be the consideration here. You should be thinking about what might happen if someone truly comes to rob your home and what if there were people when it happened? What if there are guns or other altercations and something happens? Like what Related
25/06/2023
2
It's all about wireless, self install now. The cost/benefit of wired setups for the house are no longer what they used to be. Lots of wireless options. Eufy, Arlo and…
9/04/2024
4
You should pressure clean your roof first and make sure the paint you buy also is anti mould.
28/11/2023
19
In fairness nobody gave a crap about the ACCC and the gag clauses continued in the pro forma templates of a few other builders after the ACCC took on Wisdom, and more…
