20 or 25mm water meter pipe
From the street to the meter, or from the meter to the house?
It the size of the pipes from the meter onwards that can make a difference if there is low pressure in the neighbourhood.
In the Logan City Council area in Qld, the base meter fee for 25mm is 1.5 times 20mm meter connection.
If you are on mains pressure, you might find running 25mm pipe from the 20mm meter might be helpful... how long is a piece of string I guess.
We're looking at it for our Jimboomba property at the moment, but we don't get full mains pressure, just trickle feed to top up our water tanks if they get too low. We were consider 25mm, but comments from others here show it would be just a waste of money for us in our situation.
We have a hot water copper pipe that runs from our hot water unit on one side of our house under a concrete slab to our bathroom and laundry...old house so not ideal. The…
23/07/2023
3
Plumbers 'can be' plumbers, made all the worse by self certification which the building surveyor invariably accepts as proof of compliance! The good thing is that you know know.
