Getting an occupancy certificate
Something that is a requirement when I do start to OB is living in the house whilst it is being built (In Tassie). The main reason is time to build and costs with renting at the same time. I've googled relentlessly and found some info.
My question is what is the minimum work required?
1. Waterproof. Ok so putting up inside walls does nothing for this. If it is req do I need to plaster the joints too? In all the rooms or just the occupied ones.
2. Fire alarms. Yep definitely.
3. Shower. Ok will do the master bathroom complete.
4. Toilet. As above but 1 only.
5. Laundry etc. Ok will do complete.
6. Kitchen sink Will do a bench with a sink but nothing else. Do I need a stove?
7. Balustrades. Or block access to heights. Locking doors is unacceptable so how to block?
Power, hot and cold water etc..
http://www.meander.tas.gov.au/webdata/resources/files/OBTAINING_AN_OCCUPANCY_CERTIFICATE.pdf
I live in Qld and will be building in Tassie so moving twice is not a palatable option. Just trying to save my limited funds.
Thanks for taking the time to reply.
If building in a rural location, some councils are a bit more relaxed and allow workers to temporarily live in a caravan/s provided construction of the house has commenced and the caravans are also typically hidden from public view. I.E. the new building slab has been poured and there is a working toilet on the site.
Alternatively some councils may allow a shed to be built behind the house and the shed fitted out as a granny flat with kitchen, bathroom & toilet provided construction of the house has commenced.
Something which should be done in most cases
It'll be a suburb of Hobart so no caravan and a shed would take budget from the build unfortunately. The building surveyor signs off that the work complies with what is required then the council issues a certificate.
So I'm hoping someone has first hand experience
If you are an OB you will need a substantial shed to securely store materials, tools and personal effects.
A large shed also allows one to work undercover during inclement weather.
Time will tell if a shipping container is big enough.
To keep things in perspective, my shed is as large as my house.
Plus the shed is also double storey with my temporary living quarters on the upper level; and I used every square millimetre of its ground floor space during construction as a work area, storage space and a place to have great shed parties (to appease my neighbours who initially disapproved of my shed).
Talk to the council then talk to your building surveyor
information you will get will be invaluable
Today I received my occupancy certificate for my OB after nearly one years wait.
Congratulations! Sit back and enjoy a glass. Although I'm sure there's still lots to do
I have recently joined a bush walking group but I don't feel properly dressed walking all day with them, without a nail gun and 1000 nails hanging off my belt.
2
We are in NSW and require 2 positive covenants to be placed on the property didnt really underdtand this but apparently it will take a few months, and have just been…
11/08/2023
12
I don’t think so as the floor area over 300 square meters then it is class 3….
