Tips for drilling downlight holes
My floor joists are 400-450mm apart and with air con ducting and everything I need to be exteremely precise.
Am planning to mark on the floor where each downlight hole should be but would love to hear if anyone has any other tips and tricks.
electricians generaly mark on the floor with dimensions and use a laser level, vertical to mark the ceiling after plaster.
It will take me forever to manually measure out 80+ downlights atceilig height
I couldn't rely on that. Chalk comes off way too easily for my liking.
Battens are in and everything elase is in place so decide the line of mutiple lights and measrue off the other dimensions. Use 2 people and another as a scribe but be sure they understand what they are writing down.
Alternative, Plumb bob on a string and crayon or permanant marked that will stay on the floor and be acurate enough for later posiotions. It all depends on the level of accuracy you can get away with and the errors you are willing to risk.
I am now considering getting a dewalt laser plumb bob. Has anyone used this particular one before? I'm hoping it will speed up the process a lot...
Also, what is the best way in drilling. Any particular drill bit is best to use?
In my opinion, the best way, is to temporarily mark the floor (slab) with a crayon, below where you would like the sparky to run the cables in the ceilig for the downlights, then after its been lined with plasterboard, simply measure from the nearest wall to get your lines straight, no need to get extremely fussy imo, particularly with white downlights in a white ceiling!, best time to drill is before painting, so you can see where the rafters/trusses/ceiling timbers are, give each hole a quick dust off after you've cut the hole so you dont get dust in the paint, (painter should dust off before painting anyway),
You can buy a special drill kit from the hardware store with all the common sizes in it, to drill the holes in the plasterboard. under $30 from memory contains about 5 holesaws.
cheers
woodchip
DW082K Features
* Self-Leveling plumb bob is accurate to ± 0,2mm/m
* Self-Leveling up to 4° surface angle, finds plumb in seconds - no vials or knobs to adjust
* One button operation is fast & easy to use
* Focused laser beam keeps dot small even over long distances for improved accuracy & visibility
* Cross-hair beam pattern helps user find center of beam
* Rubber overmolded housing helps maintain calibration under jobsite conditions
* Locating magnets hold Laser Plumb Bob to metal track for easy positioning
* Kit box protects unit and helps maintain calibration when stored in gang box
Thanks for that woodchip! I hadn't thought of that.
The only thing is, we've got ceiling battens throughout. I guess we now only need to worry about where the trusses are (in the opposite direction to ceiling battens).
Wiring downlights is as simple as twisting 2 wires together if you are running from an existing light but read up on the correct method for running the wires eg. drilling through joists and bearers and not over the top and make sure you clip them all at regular intervals. I can't remember the reg's anymore but i believe it used to be about 30cm apart max.
Any more complex than that and i recommend that you get a licensed electrician.
5
I use Tramex moisture meter and it will tell me instantly if the wall is cement sheet or plaster or masonite but most people dont have the equipment.
13/06/2023
1
it depends on the natural ground level, if they excavated their boundary wall needed to be built as a retaining wall. If you filled, which sounds like the case then you…
27/07/2023
5
I know foam has been around since the 90's and CSR started manufacturing Hebel in 1989, so it's definitely possible
