Water retention tank
I need DA approval and intend to submit the application myself. I have structural engineering, elevation and site plans but need to get my head around stormwater issues.
I intend to cover the deck with 16x3m insulated panel roof (48 sqm) from the existing titled roof gable. The existing title roof gutter will become impossible to service because of the awning and solar panels so I am going to remove this section of roof gutter and flow 24sqm of titled roof onto the awning. At 72sqm do I need a water retention device?
Can I include this in the scope of the roofer or do I need stormwater plumbing?
You need to ask your council about any retention tank requirements.
The tank will need an overflow pipe connected to the stormwater if the tank would otherwise overtop if an overflow pipe was not connected
11
If you can calculate the reasonable charged head from let's say 100mm below the gutter to the top of where the vertical riser's horizontal discharge pipe will be, that…
15/01/2024
7
Thank you for the generous offer. I need to get the plumber out to give me an explanation. As mentioned I haven't seen any rain water discharge from pipes 1& 3. It…
18/01/2024
Can a plumber put a tap on a rain water tank which is full? Tank is similar to one in photo. Cheers.
