Just thought Id share how I designed my current rainwater harvesting system , in case it offers ideas for others.
-roof area 370 m2
-Storage tanks 50 m from house
- wanted underground system for various reasons.
- Want easy-to-clean entry-filter.
- Long distance to collection point means 'first-flush' option would have not worked well for wet-system.
Answer:
Figure below shows 5kL tank and ONE of the two identical feed systems.
- 2 entry points to a small nearby tank ( feed from gutters at opposite sides of house), then transfer pump to main tanks.
- Above ground filters ( 2 x 90mm dia), just before tank inlets ( on tank side-wall, at top). Water enters from filter bottom as shown in figure.
- the 2 underground sections each have only 2 45-degree bends, and access covers on ends. THis will allow easy deep-cleaning at some point.
- I Can drain entire underground system with transfer pump via single tap ( i am thinking of automating this also).
Notes: THe first-filter was the biggest concern for me. I knew it would need cleaning regularly, but climbing atop-tank isnt ideal. The 'first-flush' concept wouldve requred a lot of water to go to waste to be effective.
At first I tried a spring-loaded "flip-out' filter from bunnings , which I installed on the horizontal beam before inlet, it worked fine for a while ( flip-out, clean with hose, flip-back)., but quickly become leaky to the point of big concern.
Im currently trying out this new design as shown, with 2 points:
- The overflow is essential incase the fliter is clogged
- The filters are glued permanently in place. They are actually the 'over-flow' anti-mozzie filters.( bunnings) Its very easy to clean - just squirt water down top of inner-90mm pipe. ( Although gravity should keep it somewhat clean natural, as it will fall down unless physically stuck in filter. ( probably will happen )
Rain inlet filters Ive tried. Gave up on middle one. Now using one on left ( Image from rainharvesting-com-au )
