New Build: LED Recessed Lights or Incandescent with LED bulb
Price per watt for those that have installed them in a new build?
Would you install the same amount of recessed lights if you went with the LED bulb?
Most builders I talk to dont include LED as a standard and charge a hefty upgrade.
Phillips and Cree seem to be improving technology and getting better output.
Plus I like the option to put in a smart bulb at a later date that has smart features.
We have all new LED lights in the office and some are starting to fail (maybe 2%). A bulb would be easier to swap instead of trying to find a matching recessed light.
Downlight:
There are many different styles of downlights.
Recessed light:
There is seperate bulb in that housing.
Incandescent bulb:
LED bulb:
For downlights am I better off to install LED down lights or standard recessed lights made for an incandescent bulb. I can install an LED bulb of my liking (colour and wattage).
IMHO the main issue with these is the size of the hole in your ceiling and the affect it has on your insulation - the bigger the hole the more heat escapes out and in. In terms of cost, it pretty much depends on what you want to pay. You can get downlights as cheap as a few dollars and also costing hundreds. Maybe the expensive ones are more efficient and so there is a trade off. In the end, if they are all LEDs the running costs should be roughly the same, so whether you go for a downlight or a canister with an LED bulb fitted is a matter of choice.
The downlight that arcadelt has shared is a pretty good one. Also the Trend Lighting Econoled is great for the price.
Downlights aren't the be-all end-all of lighting though. The flexibility of LED has opened up so many possibilities for creative lighting, such as the use of concealed LED strip and so on.
So I'm just reading up on this ecosystem of lights. I'm planning on putting deck lights along the outside edge of a large deck. Will need about 3 packs (18 lights) plus…
18/05/2024
Which ceiling hook to use to hang Xmas lights under Eaves in 1st floor in 2 storey façade (no…
