Ozzi Kleen systems
I think they are all much the same. I ended up using an enconocyle after asking for a recommendation here from someone who is in my area. Hopefully someone in Vic can help you out, Although enconocycle should have a local representative - they are pretty popular
Paul
A fair number of the aerobic systems have 2 pumps and an aerator. They can be noisy as the aerator can run 12-24 hours a day depending on the brand and with 3 motors, use considerably more power. I believe that most aerobic systems also require quarterly inspections.
Anyway...something to consider
Regards
RiH
I was worried about the noise.
Are there many down falls of installing a greywater system just for normal water waste ?
I really appreciate everyones comments, it helps a lot
Of the 2 systems we had far less trouble with the Ozzi Kleen, we always seemed to have to get the Septech bloke out as the alarm would trigger and we could not turn it off. The only service visit we had for the Ozzi Kleen was when we left the bath running to flush to water main (took nearly 6 hours before the water stopped running red), the water level alarm tripped. The OK was also a lot quieter than the Septech.
Both needed 1/4 inspections.
