NBNCo new house data points
im about to move into my new home in the Willowdale estate, its a nbn ready area and the house has a NBNCo box in the garage . My house came with x2 data points as standard inclusions.... As the house was already under construction when i bought it i wasnt able to ad extra data points to the 2nd floor. My question is how many data points can a setup like this take before i need to upgrade hardware? Any info is appreciated
Another option would be to use Ethernet over Power adapters. They come in pairs, so connect one end into the powerpoint (same room as above switch) and use one of the switch port. Then connect the other adapter into the powerpoint where you want the data to come out. If you want more ports where this comes out then add a switch.
Not the neatest solution but will get you data upstairs easily.
I'm currently using the below in an old house and it's working pretty well.
9
If you're referring to Eufy homebase, then just put a switch between a datapoint and put the homebase elsewhere near another device in your home unless you want teh…
12/07/2023
21
Scientists have used random matrix theory to demonstrate theoretically that the neutrino mass hierarchy can be explained mathematically. When a substance is fragmented…
13/05/2024
3
Good on you for having a go I am the opposite of DIY (so will pay a builder) - our vibe is industrial/simple so current thinking is 150mm concrete and then internally is…
