Smartphone Automation
I'm looking for something that is affordable and DIY would be ideal. So it seems this is a suitable product.
http://www.youtube.com/watch?v=mcIyQl3nIfM
Seems it is fairly simple and easy to install, and not that expensive. Works with both iPhone and Android.
Does anyone know where we can get something like this?
Thanks in advance.
There are a number of alternatives depending on your level of automation requirements.
If it just lighting then there is the lifx globe that is wireless enabled. There are a couple of others out there as well.
Another alternative for a couple hundred dollars is the NinjaBlocks http://ninjablocks.com/. Its IP enabled, web aware, comes with a range of starter sensors and an Iphone app to control it.
You need to be aware that many overseas wireless automation systems are incompatible (and possibly illegal) is Australia as we operate on different wireless frequencies even for the same protocol. Zwave is a good example of this.
Then if you want to tinker, there's Rasberry Pi and Ardunio to build your own systems.
Regards
RiH
If you want to DIY z-wave then there's quite a number of online retailers that you can buy the z-wave modules and would probably save you quite a lot of $$
http://www.tuaw.com/2013/11/12/revolv-ships-the-one-home-automation-hub-to-rule-them-all/
Then check out http://www.revolv.com
, especially the YouTube video....
1
1. optional, you can but normally just use the earth from the main switch board 2. should be enough but the distance determines voltage drop - sparky should work it…
