Hills Home Hub or own cabling
builders they recommend the Hills Home hub. Good easy all in one solution for them. The catch is this is listed at $1950
which includes only 4 data/phone/tv points. Extra data points are $95.00. I am awaiting full details but I'm pretty sure its the Home hub 600 kit
with the wall enclosure, Hills branded (who know's what brand 8 port 100mb switch) some patch panels, PSU etc and all wiring back to the enclosure.
Question is, I know what I can do for $1950 and could get a decent 6U rack and decent gbit 24 port switch + some points wired
although this would be most like have to be done after handover as the builder may not allow it during build.
Is it just easier to have something like this put in and wear the cost? and less hassles.
If worse case scenario, how much is it likely to cost to have a sparky after handover wire up 16 points (2 in 8 locations) around the house
back to a central point for me to patch into a switch?
Ozzroo
May I ask who you're building with? Also what you have mentioned is exactly what I plan to do. While the sparky is on-site doing the electrical I will be giving him all the points, cable and cash in hand to add the LAN points and wire them back to the garage or study (Haven't decided yet). Plus a couple extra TV points and power points.. Oh and lights too.
If you want less hassles definitely go through the builder as you can always go back to them if something is wrong.
Hey Ozzroo,
aussuming he has is Open or rescrited cabling license yeah sure.... or has a clue....
Timmy: We are building with Pla%^tation who make it pretty clear that no person is able to do their
own bits n pieces during build, which Im sure many still do.
Pugs: This is the trick for many i guess. I am not licenced for any electrical work yet work in IT. Quite cable to do cabling. As I mentioned I would love just to place a 6U on the wall with a decent switch and NAS etc all in one enclosure.
Is it worth perhaps approaching the sparky when we get to that stage and seeing whether they will run cables for us anyway regardless of builders. I am not sure where the builders may stand with this if they do a pre-plaster inspection and see all of these cat5 and other fancy cables everywhere.
Ozzroo
Plantation do allow other contractors during build so you shouldn't have a problem organising someone else if you have too. We're getting our Aircon and some of the cabling done this way. Shoudn't be a problem during the build process!
If you haven't received you Post Contract Variation you can VERY easily just ask them to add a clause in there allowing your own contractor onsite to do cabling. Easy done
Plantation wanted $175 per data point if you weren't using the Hills System
I'm going to do exactly that i think. Place a clause in their and hunt for a reasonable
sparky to do some network stuff.
For me to do my own wiring in my own house during the frame stage, I had to submit all my insurances and Safe Work Method Plans and Statements and be "inducted" to the site.
Ozzroo, even though you work in IT, are you registered to do cabling? As mentioned here before, all cabling must be done by a Registered cabler. Since the house will be inspected at some stage, all the appropriate forms will need to be filed. Questions may be asked by an over zealous inspector.
As for the pricing, builders prices are usually high for the actual job at hand. e.g. if a normal sparky were to do the job it would be 10%-20% cheaper. The builder knows it will cost more to do the job after handover so sets his price just under that "after handover price".
If the house is a single story, brick veneer and with reasonable access through the roof, it would be around $1600.00+gst for 8 double points and a patch panel using Krone cable and jacks mounted in plates to suit your existing plates. Add the cost of a cabinet to that.
Keep in mind that at that price, you have just spent the $1900.00+gst on the data cabling (inc cabinet) only with no TV included and no switch.
We all earn less here for a reason! lol
I am currently building with a new house with a builder and their package includes electrical wiring etc. up to an allowance amount. They had done up an electrical plan with 3 phone points ($85 each) and 2 TV points ($85 each) and 1 data point ($124 each). I have asked the builders people a number of questions eg. what kind of cables that they are going to use for connecting the phone/data points, eg. will they all be category 5/6 cables? how about the TV cables? What kind of star serve system are they going to use etc. (given that there is an item labeled "star serve" for $1390 in their fee estimate but containing no other details). So far, no answers from them at all.
I am hoping to hear from anyone here who can suggest what I should do? Can I assume that all phone/data cabling will always be category 5 and the TV cabling will be RG6 co-axial? Are these too expensive?
Grateful for any suggestions.
Many thanks.
Hi all,
Many thanks.
Many thanks.
hmm talk to them about the phone points ususlay it is 2 pair "flat" cable, data cabling should be Cat5e and for TV should Be quad sheild RG-6
even a house plan would help too as then i could advise you on what you should be putting in instead a "basic" package
personally i see no point in skimping in this or any area of the build even if you just get conduits install or predill with pull wires you can do what ever after hand over bya data cabler
Iit is worth asking your builder about third party tradies... esp if you are particular about ... Your House
bare minimum for me would be two Cat6 "data" and one RG6 (quad shield coax) "TV" points in each "main" room where you might put a TV or Computer
4
Thanks again Simeon for being so elaborate. Appreciate it. Its gives us a very idea. Kind Regards
1/04/2024
9
Hi Mofflepop, I would recommend finding a building designer to prepare plans, they should design to your specified budget. The benefit is you can tender the project out…
3/03/2024
5
We already paid for somfy motors for the blinds. The quote above was purely for “pre-wiring” so the blinds company can install the motors and blinds. That’s why we…
