Has anyone used these products? I have a room 7.5 mtrx4.5 mtr is at rear of house with 2 internal and 2 external walls will be dedicated home theatre currently has rockwoll ins on all walls with std 10mm plaster was going to upgrade with layer of 16 fire check on all walls and poss add second stuuded wall with air gap on the 2 internal walls .Noticed add for barrier board if i were to use this will it have same insulation effect as second wall on internal side ?
Thanks
Green glue and barrier board
Thanks
1
Sam There is a much stronger glue than liquid nails. It's called T Rex and will stick your timber to the concrete. Cheers Simeon
18/09/2023
Hi, I had a barrier reef pool installed less that 2 years ago and the gel coat is already fading. The colour is electric grey shimmer which isn’t available…
30/10/2023
3
I’m not a structural engineer but I’m free. you still need an engineer for the plans. I only have part of your plans, but you seem to have a 850mm drop from the side…
