Timber floor or porcelain tiles
Im looking for advise how to save money
I prefer spotted gum engineered timber however porcelain is not a bad option
Should i do it and organize myself
Do you have any contact for timber floor or porcelain
Good reference pricing for engineered timber flooring:
https://www.timberflooringclearance.com.au/engineered-timber-flooring#
Tiles are generally installed in $40-50 per sqm range (labour) and oftentimes the price depends on the size of the tiles. For bigger areas floor tiles the size difference wouldn't matter as much as for smaller areas and walls, due to more precise measurements and cutting requirements (you would have to purchase 10-15% of extra tiles).
Prices for tiles can be found here:
https://www.tfo.com.au/
The rule of the thumb is that anything between $30-60 per sqm coming from Italy and Spain is considered to be value for price choice of better than average. Rectified, of course.
Engineered timber floors will certainly be much warmer than tiles (unless you have heated floors), so if you like to walk barefooted inside, then it should be your preference.
Floor tiles become dated after a few years and are expensive to remove and replace.
I’ve just had some outdoor textured porcelain tiles installed, and they’re already getting a bit dirty from all the trees and leaves that are around. I’m looking at…
6/07/2023
1
Engineering timber is certainly a less fuss option, times cheaper to supply and install and better withstands humidity.
29/01/2024
3
They make the room much easier to clean for one, reflect more light (if light colour tiles are used), and you dont end up with dust on the top edge of tiles (cause most…
